passenger window only works sometimes
Old Jun 5, 2011 | 02:24 PM
d16y8honda's Avatar
Default passenger window only works sometimes
ive got a 1996 civic and my passenger power window has been acting up. its only sometimes working and now its stuck down and i need to get it up. my driver side window works perfectly. any suggestions?
Old Jun 6, 2011 | 10:11 AM
mundy5's Avatar
maybe you've got a bad regulator and need to replace it. Do you have power windows or manual?
Old Jun 6, 2011 | 12:07 PM
d16y8honda's Avatar
they are power.
Old Jun 6, 2011 | 12:21 PM
Broken wires in the driver's door often do that. Try opening and closing the driver's door while holding the button for the passenger window.
Old Jun 6, 2011 | 12:46 PM
mundy5's Avatar
yup, could be the wires or the window regulator. Mine turned out to be the regulator.
Old Jun 6, 2011 | 01:01 PM
d16y8honda's Avatar
was yours working randomly? and also my passenger side switch never worked just the drivers side
Old Jun 6, 2011 | 02:11 PM
mundy5's Avatar
In my case, it was the driver's side and it would work intermittently and I could hear a grinding noise while it was going up.
In your case, if it never worked, then it could very well be the wires then.
I'd try mk's suggestion of moving the door back and forth while doing it.
Also double check that there is voltage at the motor; that would be another check. If there is voltage, then we know that it is not the wire at the door nor the switch.
MMG19
Jan 13, 2013 02:53 PM
swizz977
16
Aug 26, 2010 03:30 PM
99lx
Aug 21, 2010 09:57 AM
BX_Civic
Aug 19, 2010 07:54 PM
runawaylegalsec
Apr 19, 2006 09:19 AM
