power door locks and sunroof problem...HELP!!!!
Old May 1, 2008 | 12:16 PM
Gamefreak0109's Avatar
Default power door locks and sunroof problem...HELP!!!!
i have a 99 si, all power of course. when i hit my power lock switch, the locks like half way lock, but then a fuse blows, and after that the locks and sunroof dont work ( i know, i know, thye are on the same fuse) but my question is, why would the fuse blow when i hit the locks.... it doenst happen with the sun roof, and i dont know how to fix this...
Old May 1, 2008 | 12:24 PM
Default RE: power door locks and sunroof problem...HELP!!!!
Sounds like you might have a wire that has been stripped of insulation somewhere in the power locks system rubbing against some metal, or maybe a ground wire has a break in the insulation which is rubbing against a hot wire with a break in the insulation, or a ground wire to the power locks has completely broken.
Maybe in the door jam the wires are getting pinched and as a result the insulation on the wire is stripped and/or the ground wire to one of the power locks is broken?
Old May 1, 2008 | 12:38 PM
that would make since becuause they guy who had the car before me did something with the stock door lock and just jumbled everything up, he shaved the doors...i got new ones, but when i changed um out i noticed some wires exposed and i wrapped them, maybe there are more somewhere like that, i just need to try to find um
Old May 1, 2008 | 04:27 PM
Does the fuse blow when you try to lock the doors with the driver's lock **** switch and driver's door switch?
Güero
Jun 24, 2008 08:58 PM
joedirt
Feb 27, 2008 08:37 AM
Kturner
Sep 25, 2006 08:38 AM
coolazguy
Jul 11, 2005 07:24 PM
chulo31
Apr 11, 2005 05:38 PM
