Power outlet not working
Old Jul 10, 2006 | 07:23 PM
pWnEdU's Avatar
Default Power outlet not working
My dash power outlet is not working. I checked the fuse marked "power outlet/cigarrette lighter" in the fuse box and it was fine. I also pulled apart the dash and checked out the wiring with no visible problems.
Anyone have any ideas?
Old Jul 11, 2006 | 12:40 PM
land9's Avatar
Default RE: Power outlet not working
replace the fuse anyway! noticed a few cars lately in my place, blowing fuses, where the customer uses a phone kit throught the outlet - fuse might be blown, but still making intermittent contact
check voltage with a volt-meter across 2 connectors going into outlet - if it shows 12v, check voltage at contacts in outlet, probably just a bit of corrosion - get a screwdriver and clean off contacts.
Old Jul 12, 2006 | 03:20 PM
ya but before ya try scraping the inside plug pull the fuse.LMFAO
could just be a old smoker with all kinds of ash on the middle contact point!
wet a paper towel and use something to rub it around on it and scrap it clean.
dam smokers.LMFAO
every car i get is all burned up from smokers
Old Jul 12, 2006 | 04:24 PM
land9's Avatar
haha, good one - but if he blows a fuse, at least he knows the socket is working!
Old Jul 12, 2006 | 04:51 PM
i didnt read him saying he blew a fuse....
plus non the less!
still clean the lighter plug.....
and check for power with a light tester to make sure its REALY has power thier... also check all the fuses for power.....
if ya cannt figure it out HOT WIRE IT or wire in a new lighter plug.
Old Jul 12, 2006 | 08:29 PM
pWnEdU's Avatar
I put a multi meter to it and nothing. I think I'm just going to jumper in another ignition hot circuit to it.
Thanks everyone.
Old Jul 12, 2006 | 08:59 PM
ya checked all your fuses? might wanna check that and then hot wire it. just be sure both sides of your fuses are hot..... or dead..
cjterps98
Jan 3, 2010 03:36 PM
bender
Mar 12, 2008 02:44 PM
Steven T
Dec 27, 2007 02:31 PM
curlybandit
Jul 18, 2007 01:25 PM
chrisroug
Oct 2, 2006 11:36 AM
