Power Steering Flush
Old Mar 6, 2005 | 01:27 AM
Super Mario's Avatar
Default Power Steering Flush
This wednesday I plan on doing a full power steering drain in my autoshop class. I decided the first thing that I should do is figure out how to do it. I want to completely empty out the power steerign and put new fluid in. The color is currently balck, a new bottle of p/s fluid is clear. I want to get the p/s everything as clear as possible. Any help you be greatly appreciated. And the amount of fluid would be noce too. THANKS!!!!
Old Mar 7, 2005 | 12:39 AM
Default RE: Power Steering Flush
BUMP. c'mon guys you should be working factory ferrari with all your other info....
Old Mar 7, 2005 | 02:09 AM
jwsimons's Avatar
i'm sure somebody has more on this than i , but the onkly way i can think of off hand would be similar to bleeding a saginaw pump, you simply turn the wheels from lock to lock slowly without forcing when you hit the locks, in your case remove the lower hose and drain into a bucket or similar, and have someone assist to either turn the wheels or pour new fliud, might be crud way, but sometimes simple is sweetest
norbster86
Feb 11, 2010 04:52 AM
prodigyskate5
Jan 21, 2009 01:13 PM
DaRKoN
Feb 7, 2008 07:24 PM
civic_66
Nov 20, 2006 02:44 PM
amsmk
Jan 22, 2006 01:57 AM
