Power Steering Problem???
Old Dec 30, 2009 | 01:43 PM
kyletootallwright's Avatar
Exclamation Power Steering Problem???
I have a 1997 EX 4dr. When I turn my wheels to the right, and turn them all the way, it starts to make this grinding creeking noise under my left side tire. I was told it was because my power steering fluid might be low, but I checked it and its at a normal level.
Does anyone know what other problems it may be?
Old Dec 30, 2009 | 04:03 PM
inspect your cv axles, the rubber boots are probably torn, if so then you need to replace the cv axle
Old Dec 30, 2009 | 07:38 PM
Try it with the engine off, if you still hear noises it is something else in the suspension; not the power steering.
If you hear it only while the car is moving and turned hard to one side, sort of a clicking / grinding noise, that's typically a CV joint like 94 said.
Old Dec 31, 2009 | 06:22 AM
ok thanks guys
crispydwight
May 6, 2011 06:45 AM
N2O
Sep 8, 2010 02:02 PM
norbster86
Feb 11, 2010 04:52 AM
prodigyskate5
Jan 21, 2009 01:13 PM
civic_66
Nov 20, 2006 02:44 PM
