Power window stuck
Old Jul 21, 2009 | 10:54 AM
SLiiM's Avatar
Default Power window stuck
I know it's not an electrical problem, because the drivers side window rolls up all the way, but the passenger side goes up half way, then stops. I am able to push down the on the window and it goes down, and pull up on it and it comes up. Plus it makes this weird clinking noise when I try to roll it up, any suggestions / diagnosis on how to fix.
Thanks
Old Jul 21, 2009 | 11:23 PM
churritos567's Avatar
sounds like youi have a bad window regulator motor. im not sure but the clinking sound may be that the window it popped out of track or the regulator is bent. remove the doore panel to inspect. let me know how it goes
Old Jul 22, 2009 | 06:18 AM
I agree. The regulator may be shot. But you could first try spraying some silicone lubricant into the rubber side channels to see whether the sides of the window glass are just binding in the channels.
eisenberg
Feb 14, 2010 07:14 PM
AGibney
Dec 29, 2009 05:59 PM
mtchu736
18
Dec 11, 2008 07:30 PM
boynblue
Oct 7, 2005 01:02 PM
boynblue
Oct 5, 2005 09:23 AM
