problem with brakes
Old Nov 13, 2006 | 08:36 PM
jpbody's Avatar
Default RE: problem with brakes
then what do you think the fix is because that is the only thing i changed and now the car brakes normal
Old Nov 13, 2006 | 08:54 PM
Misha's Avatar
If the problem really went away (it can reappear shortly, I had such a case), this just means you managed to fix it accidentally, when you were messing up with everything in your brakes.
I just can’t see how shims may do this. Most probably it is/was related to rotors (either quality or installation), then bearings – and I never had a case with anything else.
Old Nov 14, 2006 | 10:37 PM
b8teen's Avatar
shims reduce vibration between the pad and the caliper. if there is no shim, there would always be shaking from braking at a high rate of speed. theres a reason there in the box.
Old Nov 14, 2006 | 11:29 PM
mxs's Avatar
mxs
did you properly break in the new pads and rotors?
Old Nov 15, 2006 | 10:00 AM
jpbody's Avatar
yes i properly broken in the pads and rotors and it is still not shaking after removing the shims i drive about 60 to 70 mph everyday going to and from work and it does not shake an inch now
jonsaidthat
May 30, 2010 09:30 PM
pjredline
Mar 10, 2008 04:40 PM
sickcivic07
Nov 17, 2006 04:10 PM
ahhsimon
Jun 14, 2006 09:52 AM
faceless_civic
Nov 17, 2004 10:19 PM
