problems after header installed
title says it all. After I got done installing my header and testpipe i hear a rattling noise whenever i accelerate but it only last for 1-2 minutes then it's gone but starts up again if i turn off my engine and start it up again. Anyone know whats goign on?
id spray the pipe bots iwth some lube and try tightening them again... they might have not been tight or something between the flanges or even a crapy gasket not fiting tight....
or start it up and then try tightening the bolts again while the pipes start to heat up... just try not to burn yourself on the pipe!!!!!
okay the heatshield is not the problem and all the bolts are in place correctly and tighten with the right gaskets. But what i dont understand is.. why does it only last for 1-3 minutes then go away? if it was a bolt then ir would've stayed throughout the whole ride but it only last 1-3 minutes then goes away.
00IntegraLS
Aug 30, 2007 11:55 AM
Dorothy
May 20, 2007 09:52 AM
leomao
Feb 22, 2007 01:53 AM
jaymacf3
Nov 19, 2006 11:00 AM
Rinkrat456
Aug 28, 2006 07:03 PM
