problems starting
Old Jun 11, 2005 | 09:14 PM
89civichatch's Avatar
Default problems starting
i have a 89 hona civic hatch 1.5 4speed manual. the problem i have is that sometimes the car will not start. i will be driving then stop at the store and shut it off. i get back and it wont start. ill wait like 10 minutes (sometimes less sometimes more) and the it will start up. any ideas on what the problem is. other than that the car runs great. any help is appreciated
thanks
patrick
Old Jun 12, 2005 | 11:46 AM
Storm's Avatar
Default RE: problems starting
whadup 89, i see your new just like me.[sm=icon_cheers.gif]
have you checked you electrical connections? battery cables, wires going to the starter.
i had the same problem, and it turned out to be a lose battery cable. well actually the terminal was cracked.
Old Jun 12, 2005 | 06:35 PM
good thoughts, my car has no problem turning over, it just wont catch and fire up sometimes
Old Jun 12, 2005 | 06:59 PM
SoCaL.rider's Avatar
http://www.HondaCivicForum.com/m_65541/tm.htm
Check this out man it might help u out.
Old Jun 15, 2005 | 11:15 PM
Kappa22's Avatar
Fuel pressure regulator... I've seen the same problem on about 15 or 20 4G's, including 2 of my own.
Old Jun 16, 2005 | 12:36 AM
how big of a deal is that? and where is it located, sorry for my ignorance
Old Jun 16, 2005 | 07:15 PM
Kappa22's Avatar
Left side of the dash, underneath, around the area of the hood release. It should be a black *** with a fairly large plug going into one side of it (about 8 wires).
EDIT:
Here's how to fix it.
OK, if you hold the relay with the wire side to you, with the plug release facing down, they will be the two wires furthest to your right in the top row. Get a short piece of wire and a couple crimp-on spade connectors, and bridge those puppies together... should take care of it.
totenkopf
May 31, 2007 03:36 PM
zmalin007
Dec 14, 2005 06:56 PM
civic96RB
Sep 22, 2005 03:10 PM
Rasheed
Aug 12, 2005 10:38 AM
justbob74
May 10, 2005 09:14 PM
