Starting Problems - 92 Civic
Old Jun 21, 2005 | 12:24 PM
Rasheed's Avatar
Default Starting Problems - 92 Civic
I have a 92 Civic LX that has problems starting under certain conditions. If I try restarting it within a couple of minutes after shutting it off, it will often not start. I then often have to let it sit for a few minutes before it will start. Also, on hot sunny days it will sometimes not start. The starter will turn fine, but the car won't start.
I have tried a number of things to fix this, but nothing has worked. I've replaced the ICM and the Coil, but that did not do anything for it. Any ideas?
Old Jul 30, 2005 | 03:24 PM
tangotango99's Avatar
Default RE: Starting Problems - 92 Civic
I have the same problem also it will not start
Old Aug 11, 2005 | 05:10 PM
civicpsycho's Avatar
check this out
http://autorepair.about.com/cs/troub.../aa010301a.htm
Old Aug 12, 2005 | 10:38 AM
freebass's Avatar
its the main relay
located near the fuse panel under the dash
Scuba Steve21
13
Feb 13, 2009 11:24 AM
ashcheerit2000
Jul 7, 2007 06:57 PM
totenkopf
May 31, 2007 03:36 PM
civichonda1994tampa
Feb 3, 2007 01:47 PM
zmalin007
Dec 14, 2005 06:56 PM
