pulleys?
Old Sep 13, 2005 | 08:34 PM
civicnewbie's Avatar
Default pulleys?
I have a 97 honda civic ex (auto) should i get AEM pulleys do they make a difference if so what else do i have to get with them .
Old Sep 13, 2005 | 10:14 PM
XCM828's Avatar
Default RE: pulleys?
They'll make a little difference because they are lighter. I've heard bad things about the crank pulley though.
Old Sep 13, 2005 | 10:19 PM
StifflersMom's Avatar
Cat Fuсker
the only one I would get is the power steering (don't think there's an A/C one) hence you don't want to loose power at your alternator...that is if they are of a larger diameter
Old Sep 13, 2005 | 10:48 PM
sacicons's Avatar
AEM doesnt make a crank pulley because its not safe, but if you dont want to do a stereo system, then go for it. but if you are planning or already have pretty much anything beyond stock stereo (basically if you add an amp), then dont do the alternator one, it will lose a little juice.
Old Sep 13, 2005 | 11:06 PM
Street Sniper's Avatar
You guys dont' think it would be Ok to have the underdrive alternator pulley if you had a capacitor?
Old Sep 13, 2005 | 11:13 PM
ngoti 8tor's Avatar
An underdrive alternator pulley is okay if you're not gonna run a lot of electronics. If you have more than a stock stereo, then I wouldn't run other than a stock pulley. You want as much power flowing as possible to net you the best spark possible.
Old Sep 14, 2005 | 10:40 PM
farfrumugen's Avatar
the alt. is what charges the capacitor. all the capacitor does is store xtra energy for when you hit heavy bass,helping out the battery but the alt. still needs to charge it.
98 EJ8
Nov 10, 2005 10:44 PM
manzanaresantonio
Aug 6, 2005 08:01 PM
manzanaresantonio
Jul 30, 2005 04:57 PM
thebrodizzle
Jul 10, 2005 08:20 PM
05CivicLX
Apr 27, 2005 10:36 PM
