Questions regarding headgasket replacement.
Old Apr 26, 2011 | 08:02 PM
drumforever's Avatar
Default Questions regarding headgasket replacement.
When I pulled the head off there were some little tubes that appear to help align the head with the block. There are four holes, but I only have two tubes. Do I need all four? And, when I put the new gasket on do I need to use any gasket sealant type stuff or just the dry gasket?
Old Apr 27, 2011 | 03:29 PM
Just posting to move this thread back up. I just got my head back from the machine shop and I'd like to get it put back on, but I was hoping to get an answer first. Thanks.
Old Apr 27, 2011 | 04:03 PM
You should only have two of those alignment cylinders. If there were more it could create a situation where the slightest intolerance and the head won't go on. On my D15B7 they were in the holes in the back (intake side). Head gaskets are put on without sealer. The head and block need to be perfectly clean of old gasket material and also dry off any oil or coolant.
Old Apr 29, 2011 | 09:25 AM
MBrent's Avatar
July 2010 ROTM
if youre talking about the dowel pins, I personally think that more than 2 are necessary to properly align the headgasket.
I remember when I had my B20b scattered, that it used more than two to align the head gasket. Of course, I do not recall how many a d15 uses. Let me google it...
edit: Im stupid, d series only uses 2. Strange...
bryanb58
Apr 7, 2009 06:23 AM
wantacivicwagon
Oct 3, 2007 06:15 PM
campbuds
Jul 20, 2006 02:16 PM
Tonymore
Apr 29, 2006 04:00 PM
amsmk
Mar 2, 2006 10:00 PM
