Radius Arm bushing problem
I have a 94 Civic, while replacing the bushing on the radius arm (large one on the end of the arm, it attaches to the body) we had to loosen the2 bolts that mount it to the car. On one of the bolts the nut on the other side broke free and just spins with the bolt. How do we fix it so we can tighten it back up? There does not seem to be a way to get to the nut from inside the car or from the frame that the bolt goes into. The picture shows the part in question, this is on the drivers side front. Thanks
Scott
[IMG]local://upfiles/14213/8B1358891B164BE9A440C034FD85A057.jpg[/IMG]
Scott
well this sounds like a big problem to me, and if it was me and i couldnt find a way to get to the nut. i would try this. try to drill or punch a hole some where to get a socket or wrench in there. sorry i coulndt be more help
Well for all those that might run into the same problem here is what I found. After drilling through the floor of the car between the brake and clutch pedels I found not a hex nut but a treaded tube that should have been welded inside the chanel under the floor, but looks like it was just pressed in. No way to get a socket on it or even grab it. I am thinking now of cutting it off and replacing it with a new nut and bolt.
addiction2bass
Oct 24, 2007 05:07 PM
98 EJ8
Aug 26, 2007 09:13 PM
biocpu
May 1, 2007 05:06 PM
ClayMayTion
Jan 7, 2006 10:35 PM
