Rattling A/C Compressor?
Old Nov 10, 2007 | 11:08 PM
Default RE: Rattling A/C Compressor?
Spin the pulleys by hand to see which one is noisy. It could just be the idler pulley.
You can change the clutch (with bearing) while the compressor is on the car. It will probably be necessary to unbolt it and lower it down but leave the refrigerant hoses attached. That way you will not need to remove and recharge the refrigerant, and possibly contaminate the refrigerant system.
Old Nov 11, 2007 | 02:24 AM
dogbait's Avatar
Thanks, How can the pulley be pressed on with the compressor still in the car?
Old Nov 11, 2007 | 07:36 AM
If replacing the rotor pulley can be done without great difficulty while the refrigerant lines remain connected, then mk378's suggestion would save you considerable time and effort.
Old Nov 11, 2007 | 04:32 PM
Heat the new pulley/bearing assembly to 250 Fahrenheit (absolutely no hotter) in an oven. This will expand the bore of the bearing so it should practically drop onto the front of the compressor. Have a rubber hammer handy to finish the job before it cools if necessary.
Old Nov 11, 2007 | 06:24 PM
Again mk378 demonstrates his extensive and impressive mechanical knowledge. Do you have your oven mitts ready dogbait!
malmsteen
Nov 8, 2005 12:20 PM
Liebers
May 12, 2005 04:32 PM
tonystark
May 9, 2005 11:15 AM
Forty04
Apr 6, 2005 11:41 AM
Remmy
Feb 6, 2005 03:31 PM
