rear drums
Old Sep 22, 2007 | 09:35 AM
okwhy4's Avatar
Default rear drums
Is thier a trick to removeing the rear drums?
Old Sep 22, 2007 | 11:46 AM
Hobo's Avatar
Default RE: rear drums
I've never removed them from a Civic but if their anything like a Camry you may need to tap them with a hammer to loosen them. You may also need to adjust them to pull the brakes away from the hubs.
Old Sep 22, 2007 | 11:53 AM
koots's Avatar
there is a rubber cap in the back of the drum that allows access to the adjuster to back it off a little to get the drum off. One ofmy civics drums was rusted pretty bad but i got them off pretty easily with this method. You could also get some bolts that fit through the face of the drum that you can tighten in and it will force the drum off, but if it is stuck on pretty hard it will put extra stress on the brake components., i had to get the other drum off with this method. both can be applied as necessary, the trick is finding bolts that will match the thread pattern.
demonboy279
Jul 9, 2007 04:03 AM
ae86ks
Apr 5, 2007 11:33 PM
blink21me
Mar 5, 2007 12:10 PM
10isAce
13
Feb 10, 2007 11:56 AM
thebadgator87
Aug 27, 2006 12:55 PM
