resistor box
If your ECU requires the resistor box, it just has one input (constant 12 volts from the main relay) and 4 outputs, which go to the other wire of each fuel injector (the one not connected to the ECU). On later non-resistor setups, these 4 injector wires are connected together and run directly to the 12 volt source.
I already showed you this in your other thread.
https://www.hondacivicforum.com/m_59.../tm.htm#593524
LOCKED
LOCKED
mugen23
Dec 28, 2006 02:56 PM
