REV LIMITER HELLPP!!
Old Nov 19, 2007 | 01:19 PM
CiViC1990's Avatar
Default REV LIMITER HELLPP!!
Hi there honda lovers! I just need some help about the rev limiterI just baught!. I have Baught Alpha ARL1 Rev Limiter fromand it's compatible with both coil & electronic ignition system, Well I have a Honda Civic 1990 Hatchback & it runs on Eletronic ignition system, I Just need to know how to install this Rev limiter on my Honda, The Wires are coming out from my rev limiter are RED,BLUE & BLACK and it's manual just says RED CoilPositive+, BLUE Coil Negative - & Black Ground, And the problem is that my engineruns on eletronic ignition system not coil!Just need some Diagram or help please cause I don't have any clue!Peace!
[IMG]local://upfiles/27095/351D6F5638F0415D8BCCAADD5B1FD9AC.jpg[/IMG]
Old Nov 19, 2007 | 06:04 PM
Default RE: REV LIMITER HELLPP!!
The coil is inside the distributor. It has screw terminals for + and - and you could connect there. But I'd be leery of such a device. There should be rev-limiting software in the ECU already from the factory.
dj_ipirate
Dec 10, 2005 04:04 PM
copyguy6188
May 27, 2005 05:08 PM
wbogle
May 5, 2005 04:24 PM
burgo990
Jan 29, 2005 01:25 PM
grncivicvtec
Jan 20, 2005 09:45 PM
