reving up and down plus dies
i have a 93 civic with a d16z6 was rebuilt 90000 miles ago it revs up and down around 900 and 1300 only at idle and sometimes it will act normal and somestimes it will die but takes a secound to die when it dies it will idle down to about 100 or 200 i have replaced 3 map sensor a throttle body with tps sensor distributor cap rotor button and a coil pack. sometimes i can smell gas as well
Check if the MAP and TPS have their 5 volt power supply and ground. There may be a short / open in the wiring or (rarely) faulty ECU. The 5 volts comes from the ECU and should be present whenever the key is on.
The output wire of the TPS should be 0.4 volts with the throttle closed and increase proportionally to about 4.5 volts at wide open (do this test with the key on but engine not running). The MAP output should be about 3.5 volts with the key on not running. When running, the voltage will drop due to manifold vacuum being developed.
