Rotor removal
Old Jul 25, 2008 | 05:53 PM
subnet76's Avatar
Default Rotor removal
OK, need to remove the rotor. I took of the caliper/brakes. Now the 2 Philips head screws are stuck. Are these reverse threads? I did soak them with penetrating oil. And beat them with a hammer to try and loosen them up but with no luck. Pretty close to being stripped out I got one more shot and then Ill drill them out. If I do anyone know the screw thread size and length?
Old Jul 25, 2008 | 06:02 PM
gwl's Avatar
gwl
Default RE: Rotor removal
I used an impact screwdriver and they are not reverse threads.
Old Jul 25, 2008 | 06:31 PM
Mr Mobsta Man's Avatar
You need an impact screwdriver, a normal one will not work 9 out of 10 times.
Old Jul 25, 2008 | 08:05 PM
sacicons's Avatar
ive used one of those cheapey screwdrivers with the different tips with a handle that will bend, like a pistol grip, and put a #3 phillips in it, and walked around pick-n-pull and gotten a handful of those screws, and only stripped one with it. and ive probably broken a dozen tips in my impact screwdriver.
Old Jul 26, 2008 | 03:25 AM
315 Customs's Avatar
yea I've also used just a #3 phillips tip in a 1/4 inch socket 3/8 drive in a 3/8 ratchet and broken them loose. However I have also had to drill them out before too.
Old Jul 26, 2008 | 06:18 AM
sacicons's Avatar
maybe drop $20 and get a set of those Grabit things. they advertise them on tv, but ive seen them in hardware stores too. they seem like they would work better than most easy outs.
Old Jul 26, 2008 | 07:01 AM
bigmikew1's Avatar
i ended up jus drilling them out
Old Jul 27, 2008 | 10:26 AM
subnet76's Avatar
yep, drilled em out. Now im trying to break that axle nut off. I think they used super glue. ( I did take out the dimple ).
Old Jul 27, 2008 | 10:49 AM
The axle nut is torqued to 134 lb-ft. Use a 24 inch breaker bar to remove it.
Old Jul 27, 2008 | 12:04 PM
sacicons's Avatar
or hammer the hell out of it with a big impact wrench.
