rusty flywheel
Old Mar 2, 2009 | 08:13 PM
Ektomee's Avatar
Default rusty flywheel
I have a flywheel that's been sitting out in the weather and its rusty. Is there a way to get it cleaned up and reuse it? like is there any chemical solution or process of doing so?
should i be using that flywheel after i clean it? will it be safe?
Old Mar 2, 2009 | 09:15 PM
jpnolan's Avatar
WD40 and a scrub brush. then get it resurfaced.
Old Mar 3, 2009 | 10:26 AM
jpnolan's Avatar
Originally Posted by jlennonfan
Sand paper may do...lol
That will work fine as long as its fine grit.
Old Mar 3, 2009 | 12:35 PM
yep. just some sand paper at least 200grit... only 2 spots that needs to be rust free is the clutch area and the bolt locations. everything else is nothing but cosmetic...
but if the clutch area is ruff or scared any then take it into a shop to get turned so the area is in perfectly smooth and flat!
Old Mar 4, 2009 | 11:32 AM
Ektomee's Avatar
just take it to any auto shop and they'll fix it?
sbaksh
Jun 28, 2008 10:46 AM
strtballer98
Jun 3, 2007 10:22 AM
tdi1fun
Jan 12, 2007 09:08 PM
hwansooilmee
Jul 5, 2005 10:54 PM
jasmartini1983
Feb 5, 2005 07:47 AM
