Seafoam Treatment
Old Apr 2, 2018 | 05:45 AM
Meanie's Avatar
Default Seafoam Treatment
Uncertain if this is the area to ask. Forgive me if it isn't.
I've stumbled on some videos of Seafoam engine cleaner, the type where you spray into the throttle body and causes a crapload of smoke for awhile. The results were favorable. It was mainly used on older car and it's supposed to break down carbon buildup. Thus, I thought, what if I did that every so many miles to help eliminate or halt the carbon buildup process. I recently past 50,000 miles and plan to do some spring maintenance (filters and fluids). I thought it would be a good idea now and then maybe at 100,000 miles and so on.
Anyone use Seafoam and/or recommend this strategy?
Thanks
Old Apr 2, 2018 | 09:45 AM
mhammond1127's Avatar
I’ve used it for bad gas or as just a general cleaning method for fuel system but as far as throttle body goes, I’ve only done it once on my moms Ford Expedition. It didn’t take to it to well, actually caused it to run really rough and didn’t do what I was intending or as what they advertise it does. But it is still your decision on whether to use it or not. That was just my experience.
Old Apr 2, 2018 | 10:28 AM
Meanie's Avatar
Those are my uses for it as well. I use it yearly for storage of my seasonal engines and never had a problem, though, oddly, never used it in my car's fuel system. Then I saw the vid and thought, hmmm.
Old Apr 2, 2018 | 01:36 PM
I mean you can try it, just have some money on the side in case you have to replace the throttle body, I mean that’s worse case scenario
Old Apr 8, 2018 | 03:53 PM
Duane4238's Avatar
Find out, first, if the Seafoam is compatible with your throttle body and all of the sensors, like the map and maf sensors. I know there are certain carb cleaners that will eat up those things as quickly as you spray them. You could cause yourself a sh*tload of problems if it's not for that type of use.
Duane
Gonzo
May 4, 2008 06:31 PM
koots
Feb 13, 2008 07:14 PM
My04Civic
Nov 19, 2007 05:31 PM
that_guy5
Jan 16, 2007 06:18 PM
koots
Aug 12, 2006 12:50 PM
