Setting TPS sensor.
Old Aug 5, 2006 | 07:51 PM
glada96EX's Avatar
Default Setting TPS sensor.
Ok I did a search and found nothing on setting the TPS. Anyone know what voltage? Also how should I probe the wires? Its a JDM B16a if that makes a difference. Thanks.
Old Aug 5, 2006 | 10:08 PM
fglaustin's Avatar
Default RE: Setting TPS sensor.
did you once set those on an earlier model ?
you have a 92 to 95 civic ?
there were spec to set for 1987 and earlier. dont think the later models (after 87) have settings (just a supposition though - not positive)
Old Aug 6, 2006 | 11:18 AM
glada96EX's Avatar
It is adjustable. It dosnt have the riveted screw either. Im just not sure if I have to expose wires or if theres a way to test voltage with out doing that? A friend told me to stick pins through the bottom of the plug and test it that way but I cant get a reading.
Civic Si 00
Nov 10, 2007 09:02 PM
TIcivic00
Sep 7, 2007 07:27 AM
patcheway
May 30, 2006 03:29 PM
ef4life
ED-EF Swaps
16
Jan 25, 2006 04:51 PM
fast93civic
Jun 11, 2005 10:19 PM
