Sever Sluggish,bogging and jumpy acceleration
I have a 95' Honda Civic EX. I installed a new throttle body gasket. Immediately after I had a fluctuating idle from 1000 to 1700. I drove it like this for a week or so and the sluggish behavior started occurring slowly. I noticed that the gasket (not OEM) was blocking a air hole on the throttle body. I replaced it with one that i bought directly from Honda and the flucuating idle was fixed. But the sluggish behavior is still present when I accelerate (idles PERFECT) and seems to be getting worse.If i rev the engine in neutral it does the same thing. but if I feather the RPMS up it wont do it. When driving, If i accelerate very slow it will not do it as badly. Things that have been don to try and fix it--
I did get a CEL but it went away after i turned the car off. I checked for codes and I got 3,7,and 9 Which are MAP sensor, TPS, and cylinder sensor??? The MAP and TPS are there because I swapped throttle bodies and had to unplug them but not sure what or why on the cylinder sensor????
-Checked ignition timing--GOOD
-Checked for vacuum leaks--NONE
-Coolant level perfect--Just had it flushed
-Swapped out throttle bodies--NO CHANGE
Please help, I had no problems with my car till this whole gasket problem. Im on the verge of dropping it off at the junk yard!!!
I did get a CEL but it went away, and all that stuff is new. I have only had this car for about 2 months, so i don't know its history but the fuels filter "looks" brand new. Its all glossy and clean, but looks can be deceiving. will replace fuel filter tomorrow.
Pulled codes 3,7,9, and 14. I think i have 3 and 7 cause I swapped the throttle body. I did unplug the IAVC at one point so thats probably why i got 14 the one i dont get is 9, the cylinder sensor....could this be my problem?
Back firing may indicate a problem with the ignition timing. Did you check the ignition timing with a timing gun and the service connector jumped (same as pulling CEL codes)? What mark on the crank pulley did the pointer align with?
OK..well its running a little better. I can actually accelerate up to speed. But its still backfiring with pedal to the floor, bogging down especialy in 1st and 2nd. and its still bucking a lot in 1st and 2nd.???? When I put the pedal to the floor it bogs down and makes a loud bellowing then will backfire. No CEL tho
