Shake between 50 & 65???
Old Mar 6, 2007 | 08:18 AM
006r's Avatar
Default Shake between 50 & 65???
I have a 95 LX and it has been great. But the other day I hit a driveway entrance maybe a bit faster than I should have, enough to get the airdam to hit...the next dayit has a steering wheel shake only between 50-65 mph. Its not related to engine RPM and above 65 it goes away as well. Any ideas? Tie rod ends? Ball joints? Let me know some ideas that I can check tonight.
Old Mar 6, 2007 | 01:00 PM
sillyredcivic's Avatar
Default RE: Shake between 50 & 65???
alignment? That would be my best guess. What about going around corners and stuff? any sounds out of the axles or clunking noises?
Old Mar 6, 2007 | 01:55 PM
006r's Avatar
Not sure on the alignment as it still tracks straight down the road, could be I guess...
No weird clunking noises either, nothing while turning or accelerating or both...
Old Mar 6, 2007 | 02:01 PM
006r's Avatar
I think it might be the tires, maybe a bad belt in the tire?? Thats all I can think of.
Old Mar 6, 2007 | 06:31 PM
jim9418's Avatar
Maybe you popped a wheel weight off if you hit hard enogh. May just need a balance. Look and see if there any "clean" places where a wheel weight has been. Worth a look.
Old Mar 6, 2007 | 06:47 PM
Fiirkan's Avatar
Whats your climate like? if it is cold and snowy then it could be ice buildup on the control arm, that will do it, just take a hose with hot water like at a wash place and spray off in behind the wheels
Old Mar 7, 2007 | 09:51 PM
AgentofDarkness's Avatar
Have the wheel balanced. You might have damaged the wheel when you hit the curb. Things that spin are kinda wierd with the weight distribution, you might have runout on your wheel.
firblitz
Jan 28, 2007 12:33 PM
SmilieY
May 20, 2006 10:53 AM
rajantsr
13
May 19, 2006 04:31 PM
AgentofDarkness
Oct 9, 2005 11:17 PM
bain0005
Jul 8, 2005 02:23 AM
