shifting
Old Jul 29, 2007 | 04:50 PM
96 civic in ohio's Avatar
Default shifting
When I go from 2nd to 3rd It grinds doesnt matter what speed. When I bought the car they said it had a new clutch and pressure plates,I thought maybe its just an adjustment please let me know what you think
Old Jul 29, 2007 | 05:49 PM
Live_4it's Avatar
Default RE: shifting
Does it only do it when your going fast and trying to shift quickly, or all the time?
Old Jul 29, 2007 | 06:10 PM
both butmore when I go fast
Old Jul 29, 2007 | 06:28 PM
ltkenbo's Avatar
Do you push the clutch all the way to the floor when you shift? You could also check the pedal adjustment to make sure it engages the clutch properly.
Old Jul 29, 2007 | 06:33 PM
Mr Mobsta Man's Avatar
3rd gear syncro is probably bad/worn. Happens to a lot of hondas I think. Mine is the same way. Nothing to worry about really.
Old Jul 30, 2007 | 02:04 AM
SovXietday's Avatar
2-3 synchro and sleeve are probably shot. Happens a lot, not necessarily important to fix but you're going to have to do it sometime. If you've never opened a tranny before I suggest not doing it, you have to pull apart the entire countershaft in order to get to that sychro. Might as well as change the mainshaft and countershaft bearings while you're at it as well, as they're probably also going bad.
From a Honda dealer, you're looking at about ~$200 + labor.
Or you can buy a trans that you know is good and swap it in with a friend.
ImportTrendz
May 23, 2007 08:36 PM
Forty04
Mar 31, 2005 03:34 PM
fast93civic
Mar 22, 2005 01:43 PM
Narcoleptic724
Dec 3, 2004 08:58 AM
kobejelbryant8
Jul 15, 2004 08:31 PM
