Signal is having electrical problems
Old Jun 22, 2010 | 07:49 AM
xnick101's Avatar
Default Signal is having electrical problems
My signal works almost 90% of the time but sometimes it starts clicking fast like the bulb is bad and it does it for both the lights.. i tried replacing and nothing new.. fuse problem?
Old Jun 22, 2010 | 07:56 AM
Put the 4-ways on and walk around to confirm that all the bulbs work. A bad ground in the trunk or front of the car will also cause this as some of the bulbs will be on dim or not at all. Bad grounds usually cause an interaction with turning the headlights on or pressing the brake. If the bulb system seems OK you might try a new blinker relay.
cabell22
Jan 8, 2015 06:44 PM
94VTECoupe
May 18, 2007 06:49 AM
nvthis1
Mar 14, 2007 11:16 AM
jrobles26
Jan 1, 2006 11:05 PM
civic96RB
Sep 22, 2005 03:10 PM
