Since everyone else's check engine light is on....
Old Oct 17, 2008 | 05:41 AM
00Si_Bennett's Avatar
Default Since everyone else's check engine light is on....
So is mine. It tests fine at AutoZone, but the guy said it was on because the engine was swapped. Any ideas on how to turn it off?
2000 Civic Si - Swapped for B18B1
Old Oct 17, 2008 | 06:16 AM
What specific code(s) were retrieved? If you don't know, retrieve them yourself at home (see link in my signature). Post the codes in this thread.
Old Oct 17, 2008 | 08:16 AM
Results:
3 MAP - manifold absolute pressure sensor
22 VTEC pressure valve
23 Knock sensor
41 Primary oxygen sensor heater
22 makes sense, the B18B1 isn't VTEC. Mind explaining the others and common fixes?
Old Oct 17, 2008 | 08:44 AM
Originally Posted by 00Si_Bennett
Results:
23 Knock sensor
As mentioned by the guy at AutoZone, first look into the possibility that the CEL codes indicate an incompatibility between sensors that the 2000 Si ECU expects to see and those of the B18B1 engine. For example, does the B18B1 lack a knock sensor? Are the primary O2 sensors different for the two engines? Also look into the possibility that problems lie with differences between the B16 and B18 engine wire harnesses. Hopefully, some of the forum's engine swap experts can help you further with the details.
Old Oct 17, 2008 | 10:28 AM
Yea, B18B1 doesn't have VTEC, which leads me to believe you didn't swap the ECU. Get the B18B1 ECU, and I bet your codes all go away.
civic_burns_all
Feb 27, 2008 03:24 PM
DOWA16
Mar 1, 2007 01:39 PM
Fiirkan
Jun 19, 2006 04:10 PM
andryuha
Nov 27, 2005 11:26 AM
Mad7s
13
Mar 15, 2005 10:38 PM
