Smog results help!!!!
Old Apr 13, 2010 | 07:19 PM
Melvinsaniac's Avatar
Default Smog results help!!!!
What do you think?
I desperately need help!
I drive a 1996 Honda Civic DX.
15mph- HC: MAX-66 ;Meas-71 CO:MAX-0.57 ; Meas-0.64
NO:MAX-487 Meas-471
25mph-HC: MAX-49 ; MEAS-66 CO:MAX-0.55 MEAS-0.76 NO:MAX-774 MEAS-458
After the test I bought new dist. cap, dist. rotor, spark plug wires, spark plugs.
I plan to test again soon, anymore suggestions?
Old Apr 14, 2010 | 03:36 AM
We don't do emissions testing here so I dont know what any of those numbers mean. Did they tell you specifically why you failed? Are you getting any CEL's, and if so have you pulled the codes?
Old Apr 14, 2010 | 05:07 AM
Nope. I'm not throwing any CEL's. I shoould also mention, I'm from the Peoples Republic of California.
Old Apr 14, 2010 | 06:24 AM
Clean out your EGR system, if you have one. I don't know if the California versions did.
High HC and CO typically means running rich, check the fuel pressure. But a rich mixture will drive down NO. Since 15 mph NO is also up close to the limit it could be that your catalytic converter is tired.
cedlykwhoa
Mar 22, 2010 10:18 PM
fast93civic
Apr 19, 2005 08:06 PM
Super Mario
Nov 29, 2004 06:09 PM
