speedo not working
Old Jan 31, 2012 | 10:40 PM
Christo19's Avatar
Default speedo not working
1995 civic 4 door LX
My speedometer doest work it just sits at 20 mph, one time while driving it went up to 70 but then dropped back down. Also the odometer and trip do not work.
Any ideas? theres a sensor on the tranny for it right? that could be bad? or the cluster?
thanks!
-Christo
Old Jan 31, 2012 | 11:13 PM
f22_strike's Avatar
i had that problem b4 there is a sensor on the back of the tranny plug could be lose or a pin could be broke off like mine but unlikly the sensor if it sits at 20 when your not moving
Old Feb 1, 2012 | 06:04 AM
Sounds like the VSS needs to be replaced. You can check it with a multimeter, too. Are you getting a check engine light after driving for a little bit?
The VSS is on the back of the transmission.
Old Feb 1, 2012 | 06:25 AM
Speedometer should read zero with the sensor unplugged. If it doesn't it seems the speedometer head would be bad.
Old Feb 1, 2012 | 09:00 PM
Christo19's Avatar
i have no engine check lights
Old Feb 3, 2012 | 07:14 PM
Christo19's Avatar
put a "new" speed sensor in from a junk yard and no change, it must be the cluster.....
chrisroug
Oct 2, 2006 11:36 AM
derekdunham
Nov 20, 2005 10:30 AM
nesh_uk
Oct 30, 2005 12:14 PM
cfauvel
Sep 22, 2005 01:23 PM
derekdunham
Jul 25, 2005 10:39 AM
