speedo quits when hlights on
thanx ronj!! i have already removed and cleaned the vss with elect. no-flash cleaner and have also checked the g201 and g401. all is well, i had good speedo all the way to work (25 mi.) and i hope it gets me home in the a.m. (nightshifter) when i left work this morning i turned on defrst,hdlts and radio and i can't believe how i lost voltage so dramatically!!
You seem to have a power problem. Try cleaning the battery posts, connectors, and ground wire on the chassis.
Afterward, with the engine idling, check the voltage across the battery posts without a load and with high load (high beams and other accessories ON). You may have a bad battery or alternator.
dpemble
02-18-2014 04:29 AM
