Speedometer clip
Old Feb 28, 2005 | 01:34 PM
billybaroo's Avatar
Default Speedometer clip
Hello all,
My brother and I replaced the clutch on his 1991 civic this weekend, and at the very end we were both a little stumped on re-attaching the speedo cable at the transaxle. The cylinder that the cable goes into has a slit on one side, but we could not figure how to use the clip in conjunction with the one slit. We ended up puting the clip around the cylinder which allowed one side of the clip to fall into the slit and keep the cable from coming out but it did not seem to hold it very well. The boot does not seem to go over it very well in this position either.
Not sure if we distorted the clip on removal, and for the life of us we cannot remember what position it was in when we removed it.
Any help would be great. Other than that the clutch is great now, and we did the drive axles as well because the CV joints were done. The biggest issue was breaking all of the balljoints free that had to be removed without destroying the studs or the boots.
Anyway, thanks in advance....
Old Feb 28, 2005 | 08:34 PM
sacicons's Avatar
Default RE: Speedometer clip
havent done a cable speedo in a long time, so i cant help you with that, but next time get a "pickle fork" or a ball joint separator. you just pound it into the ball joints and it pops the ball joint free. you can even get an attachment for an air chisel. they would make short work of those pesky things.
Old Mar 1, 2005 | 08:34 AM
billybaroo's Avatar
Actually we ended up using a pickle fork for most of them, however the pressure of the fork tended to tear the rubber seal of the ball joint most of the times just due to the pressure of the fork against them. The first one tore quite bad so we tried putting grease on the fork and that helped reduce the tearing, though they did still tear a little bit. Some of them were on extremely tight!!
Old Mar 1, 2005 | 08:52 PM
sacicons's Avatar
MOST of them are extremely tight.[:@]
Old Mar 2, 2005 | 02:31 PM
billybaroo's Avatar
Oh yeah, you know it. The LCA balljoints took a pickle fork AND a 20lb. sledgehammer.
Anyway, I am surprised no one has done the speedo-clip lately as it has to come off if the transaxle or engine needs to come out. [sm=boohoo.gif]
Old Mar 2, 2005 | 11:33 PM
sacicons's Avatar
i broke my hand hitting it with a 24oz ballpeen trying to break those suckers loose. actually, i broke it the second time that i hit it that night. then i hit it two more times that night, then dropped the starter on it. its been like 3 months, and its still swollen. (barely)
twon
Sep 9, 2005 07:39 PM
LEVIII
Jul 21, 2005 11:19 AM
AnakinKenobe
Mar 6, 2005 11:13 PM
svxin
Feb 7, 2005 04:25 PM
blkjak
Nov 21, 2004 07:24 AM
