Speedometer Dont Work?
Old Aug 2, 2007 | 12:47 PM
Finney_3's Avatar
Default Speedometer Dont Work?
Do i change the Speed Sensor. Or Could it possibly be the Cluster Itself....?
Anything will help. Thanks
Old Aug 2, 2007 | 12:50 PM
Default RE: Speedometer Dont Work?
If the odometer still works, definitely sensor is OK; change the cluster. If the CEL comes on, probably sensor trouble, pull ECU code to confirm. If it's looking like it's the sensor, check for loose or corroded wires at the sensor plug before buying a new sensor.
Old Aug 2, 2007 | 12:52 PM
Finney_3's Avatar
Thanks that is the same stuff my step dad just said hahaa.....
Old Aug 2, 2007 | 01:04 PM
ej6buddy's Avatar
yes, it's common with almost all vehicles. for some reason, with civics, it just likes to happen more so.
Old Aug 10, 2007 | 04:24 AM
yingster's Avatar
if the sensor is ok, don't change the cluster. to save money on your behalf go to discounthondaparts.com and try to buy the little unit within the cluster itself. it should cost no more than 80 dollar for the unit. hey, if can't find that site let me know and i'll try to help u.
Old Aug 12, 2007 | 03:14 PM
kdh621's Avatar
My speedometer was sticking at 20mph about 50% of the time I was driving. The odomoter wasn't working if the speedometer wasn't moving at the time. My mechanic diagnosed a cracked speedometer head and I had to replace it and have the odometer reset. Speed sensor was fine.
mxstylez
Mar 30, 2006 08:44 AM
SoCalROB
Nov 21, 2005 10:01 AM
civicg
Nov 1, 2005 09:28 AM
lilol89crx
Jul 29, 2004 06:56 PM
drrocket0302
Jul 20, 2004 11:30 PM
