Speedometer Needle doesn't work/move
Old Jul 6, 2007 | 05:14 PM
fastfrankie's Avatar
Default Speedometer Needle doesn't work/move
Last question. I have a 1993 Civic and the speedometer needle doesn't move when you drive. Is there just a part I can replace or do I need an entire cluster from the junkyard? What is the cheapest/easiest fix? Thanks alot!!
Old Jul 6, 2007 | 06:39 PM
ej6buddy's Avatar
Default RE: Speedometer Needle doesn't work/move
it's either:
-vehicle speed sensor
-speedo needle motor is broken
have you tampered with anything in the past that might have triggered it to quit working?
Old Jul 7, 2007 | 07:45 AM
If the odometer still works it's going to be the speedometer unit itself, simplest to replace the whole cluster. If the odometer doesn't work then it could be the VSS, that should also set a code in the ECU. First check under the hood that the VSS is securely plugged in.
Old Jul 7, 2007 | 08:06 AM
dito.... if your milage is changing then its just your needle....
BUT if the milage doesnt change then it could be that speed sensor...
Old Jul 7, 2007 | 04:33 PM
Can someone tell me where the VSS or cehicle speed sensor is located? I haven't noticed whether the odometer is working but I will drive the car tomorrow and find out to determine what it may be. Do VSS's go bad/common problem?
Old Jul 7, 2007 | 04:41 PM
ej6buddy's Avatar
yes, they can go bad sometimes, especially during engine swaps.
Old Jul 7, 2007 | 05:02 PM
Well mine had its engine changed out a few years ago from what I was told. Where is the VSS exactly/what does it look like? Is this something I can buy locally at Advanced Auto/Autozone. etc?How much for the part?
Old Jul 8, 2007 | 10:08 AM
It's on top of the transmission (transaxle) near the back, on the part where the CV axles go in. Has a three-wire plug on top of the sensor. I think it's expensive enough that you want to be pretty sure it is bad before replacing it.
Old Jul 8, 2007 | 11:27 AM
Solid_Snake's Avatar
VSS location (pictures taken on a '99 EX)
Old Jul 8, 2007 | 11:28 AM
The VSS is held by one 10mm bolt.
Workman23
May 14, 2014 11:30 AM
97Ej8
Mar 26, 2012 06:29 AM
project94
Mar 21, 2012 04:38 AM
gfield13
Feb 19, 2008 11:02 AM
lilol89crx
Jul 29, 2004 06:56 PM
