speedometer not working...
Old Jun 23, 2010 | 09:26 PM
wicked696's Avatar
Cool speedometer not working...
it dont work,??
Old Jun 23, 2010 | 10:58 PM
We Are None's Avatar
Banned
what car? how many miles/ Km ? does it just not work or works sometimes? this problem happened to me
Old Jun 24, 2010 | 05:03 AM
Speedometer stays at zero diagnosis:
Odometer keeps rolling normally, no CEL -- speedometer head / cluster is bad.
Odometer stopped, CEL on -- most likely sensor problem.
Odometer stopped, CEL not on -- most likely head problem.
Peculiar to certain model years (since you didn't say which year you have):
pre 1992 have mechanical speedometer cable instead of electronic sensor. Cable is prone to break: disconnect transmission end, pull out cable core and inspect.
1996 to 2000 models prone to fuse 15 problem.
Old Jun 24, 2010 | 05:57 AM
wicked696's Avatar
its a 97 ex honda...i think its got 70,000 miles on it, the speedometer did work at 1 time b4 i pulled the tyranny out to do some other stuff to the car and now it wont even budge..
Old Jun 24, 2010 | 06:59 AM
Did you plug the speed sensor back in? The sensor is located on top of the back part of the transmission, above where the CV axles go in. It has a 3 wire plug.
Also a 97 is real prone to fuse 15 problem, where the wires on the back of the engine short out to the intake manifold bracket and blow fuse #15 under the dash. This cuts power to the speed sensor (among other things) and the speedometer stops working. So check if fuse #15 under the dash is blown.
Old Jun 24, 2010 | 07:57 AM
wicked696's Avatar
yeah i double checked the speed sensor wire and its on fine, but i didnt think of the fuse or the possibility that it could be..thanks.
Old Jun 25, 2010 | 10:27 AM
wicked696's Avatar
i replaced the fuse #15 and still nothing...
Old Jun 25, 2010 | 10:37 AM
CEL codes?
Old Jun 25, 2010 | 10:49 AM
Was the fuse blown? If it was, you need to fix the wires behind the engine or the new fuse is just going to blow too.
Old Jun 26, 2010 | 04:28 PM
wicked696's Avatar
the fuse didn't appear to be blown, and ill take a look at the wires behind the intake ...
gfield13
Feb 19, 2008 11:02 AM
classic97
Feb 9, 2008 03:43 AM
pjperez64
Aug 6, 2007 09:03 AM
rdas45
Mar 2, 2007 08:03 AM
chrisroug
Oct 2, 2006 11:36 AM
