speedometer wrong
Old May 30, 2007 | 03:47 AM
sweptwing's Avatar
Default speedometer wrong
My speedometer reads high. If I am indicating 70 I am only going about 65. Seems to be fairly consistent throughout the range of speeds. The tires are the factory size. The odometer follows the inaccuracy by being high by 4 tenths every 10 miles. Do you think it could be the speed sensor? Thanks in advance for any help.
Old May 30, 2007 | 02:32 PM
Kommando's Avatar
Default RE: speedometer wrong
You haven't changed your tranny/gearing have ya? Are the tires pretty worn, or low on air? If they're the right rolling size, I would think the speed sensor or indicatorneedlea likely culprit, especially since you stated that the discrepancy is fairly consistent at about 5MPHthroughout.
Incorrect tire size or gearing causes an inconsistency by percentage. The faster you go, the more the discrepancy is. The speed sensor or indicator needlecould be "off" by 5MPH no matter what speed you're going.
Old May 30, 2007 | 07:56 PM
brokenarmboy19's Avatar
leave it no more tickets
Old May 30, 2007 | 08:22 PM
Roadkillboy0's Avatar
ORIGINAL: brokenarmboy19
+1
Old May 31, 2007 | 01:22 PM
little dante's Avatar
lol...
check the speed sensor... also reset the ECU
Old May 31, 2007 | 01:37 PM
sweptwing's Avatar
Changed the speed sensor and still no change. Is there a chance someone in the past changed the gearing on the speed sensor to transmission gear? I know you can do that on standard american cars, can it be done on these too?
Old Jun 4, 2007 | 05:22 PM
sweptwing's Avatar
what other wires should I be checking?
Old Jun 5, 2007 | 03:47 AM
mlobitz's Avatar
Member
r u sure the tires match the sticker in the driver door jam?
elfreaky70363
ED-EF Swaps
Jun 13, 2005 08:53 AM
sacicons
Feb 13, 2005 12:41 AM
hondabboy
Jan 31, 2005 11:21 PM
Mad7s
Dec 15, 2004 09:01 PM
White_Devil
Aug 19, 2004 11:48 PM
