Squeakin' and Creakin' Clutch
Old Aug 22, 2008 | 09:57 PM
I know how you feel.
Old Aug 23, 2008 | 04:05 AM
ic892003's Avatar
ive had that noise for a year and a half now. i think its common on civics, i wouldnt worry about it but of course thats me, i think the pedal just needs to be greased up
Old Aug 23, 2008 | 08:30 AM
mundy5's Avatar
this has been a very helpful thread since my 98 is also having this noise. I noticed that it is most loud in the morning after sitting overnight. but when it gets hot or the car is warmed up, the noise is minimal if non-existent at times.
I doubt this is the actual clutch pedal and I've sprayed the daylights out of it with WD-40 with no improvement. plus, i had my wife push the pedal in and the noise is definitely coming out of the slave cylinder area.
I will have to try to put some grease on that part soon. it sure is annoying as others have said.
Old Aug 23, 2008 | 03:27 PM
JakeyMan07's Avatar
i had a squeeky clutch since i bought my civic never really worried about it and today i changed the tran fluid and not heard it yet and i used to hear it everytime i push the clutch in now since i changed the tran fluid it does not even do it anymore so i am happy
Old Aug 23, 2008 | 03:36 PM
Success!
Greased it up as instructed by RonJ, and the noise went away.
Advice to anyone attempting this:
It takes quite a bit of grease to get the noise to go away completely.
Old Aug 23, 2008 | 06:52 PM
Trust, that's great. Do you think most of the squeaking was coming from the interface between the slave cylinder and release fork. Or did you also need to add grease to the slave cylinder boot? I've got to grease mine now!
Old Aug 23, 2008 | 07:06 PM
I just greased the hell out of everything. LOL
I greased the release fork/slave cylinder contact area and underneath the boot. i also sprayed wd-40 on the pedal linkage under the dash.
Old Aug 24, 2008 | 12:38 PM
Live_4it's Avatar
Success!
Did you take any pics while you were down there? You should do a DIY, I've been thinking of doing this but thought it would be too hard to get to without a lift or removing other parts.
Old Aug 24, 2008 | 12:47 PM
nah i didn't get any pics.
it's pretty easy. here's some little short instructions.
1. just push the slave cylinder/clutch fork rubber cover off to the side
2. pull the slave cylinder boot off a little bit
3. put a bunch of brake grease under the slave cylinder boot
4. reinstall the boot
5. grease the part where the fork meets the slave cylinder. (use a lot of grease)
6. reinstall the rubber cover
7. go test the clutch
8. if clutch still makes some noise, repeat steps 1-6 and apply more grease.
Old Aug 24, 2008 | 05:18 PM
Thanks Trust.
