srs light
Old Aug 18, 2010 | 05:22 AM
jdmtuner's Avatar
Default srs light
how do u reset the srs light on a 96 civic
Old Aug 18, 2010 | 04:16 PM
silver2000civic's Avatar
The only way i know how to reset it is to fix the problem that is causing it to come on. Maybe a bad air bag or a wire unpluged.
Old Aug 19, 2010 | 11:44 AM
jdmtuner's Avatar
well the light came on after i disconnected the steering column to replace the rack and pinion so idk what the problem is
Old Aug 19, 2010 | 11:57 AM
BurningRubber's Avatar
Did you plug it back in?
Old Aug 19, 2010 | 12:21 PM
You probably broke the clock spring by getting the wheel out of sync with the rack. Does the horn still work? It goes through the clock spring too.
fivebells
Aug 9, 2014 06:10 PM
houstonwide
Nov 17, 2005 09:57 PM
vmf
Aug 1, 2005 11:43 AM
Josh1122
May 4, 2005 05:50 PM
ettrump
Feb 23, 2005 05:28 PM
