Starting
When i start my car i gotta sit there and feather the gas pedal untill i hear the intake start sucking air. i thought it was the map sensor so i put one on it and its still doing it, runs a little better though. any ideas??
Could be a stuck/clogged IACV. The IACV (and the FITV if below 60 F) are supposed to let maximum air in during starting so it is not necessary to press the gas pedal.
Also check your TPS with a voltmeter. Turn the key on but don't start. Connect meter plus to the center wire of the sensor (sensor still plugged in) and minus to ground. Voltage should start at 0.5 volts and increase smoothly to 4.5 as you open the throttle.
That's probably the FITV. (Fast Idle Thermal Valve) When the coolant is below 60 degrees F, i.e. right after a cold start in the winter time, it lets even more air into the engine to make it idle fast. Once the coolant warms up even a little, it closes off.
On a manual transmission car the IACV is usually on the back of the throttle body. It also has coolant in it. The purpose of the coolant here is to warm up the valve to preheat the air flowing through it. This makes the idle smoother in cold weather.
The IACV has an electrical connection, the FITV does not.
totenkopf
May 31, 2007 03:36 PM
raphn
Jun 14, 2004 02:07 PM
