starting to get frustrated
Old Feb 18, 2007 | 05:04 PM
ic892003's Avatar
Default starting to get frustrated
i changed my fuel filter, cleaned my injectors tested my fuel pump, added antifreeze, spark plugs were changed 4 months ago and my car is still starting up funny..... this morning it took two cranks to start when going to work.... then after work when it was warmer outside it took 8 cranks...... im getting tired off this crap ... should i just leave it at the mechanic??
Old Feb 18, 2007 | 05:14 PM
2slo4u's Avatar
Default RE: starting to get frustrated
What car do you have? It might be a bad sensor.
Old Feb 18, 2007 | 05:22 PM
ic892003's Avatar
1992 honda civic lx, the haynes manual says this problem is common among 92 civics, its a leaking check valve in the fuel pump..... but my fuel pump tested fine
Old Feb 18, 2007 | 07:16 PM
riceburner700's Avatar
more than likely when you leave your car for a while the fuel pressure will drop, hince when you crank your car it has to build up fuel pressure.
Old Feb 18, 2007 | 09:34 PM
ic892003's Avatar
does the cold weather cause low pressure or is it the pump or wat?
D16Y8Civic93
Oct 25, 2011 06:23 PM
jpinperth
Sep 6, 2010 02:59 AM
teri.teri
Aug 9, 2010 05:41 PM
DaPornStar
Jun 14, 2007 01:51 PM
jake11375
Oct 7, 2005 04:17 PM
