Starting problems - no crank, no clicking, but do have all power (not battery)
Old Jul 10, 2006 | 06:18 PM
snosurfa7's Avatar
Default Starting problems - no crank, no clicking, but do have all power (not battery)
96 HX w/ 230K...
This only happens after I let the car sit for awhile (30 mins plus), and then if I shut it off right after it happens and turn it back on the problem is nonexistent:
I turn the key and I get all power/lights/radio, but no click, no turning over of the motor - nothing - and then - at least for now - about 10 seconds later of just holding my key turned the Civic starts up.
I have an aftermarket alarm, and it acted up when I pulled the headboard down today, though I think this is mere coincidence, as all I have running up there is an antenna for the alarm.
Bad connection? Starter and/or solenoid?
The thing that gets me is how it ONLY does if the car sits for more than 30 mins...
Old Jul 10, 2006 | 07:29 PM
Saltyhatch's Avatar
Default RE: Starting problems - no crank, no clicking, but do have all power (not battery)
could be the starter-you might remove it and have it tested. They fail gradually sometimes.
Do you hear the fuel pump prime for a few seconds when you turn the key? The sound should come from the back seat area...
I had the same problem, but it turned out to be a mouse had chewed thru a wire harness, so you could look around for that, too.
Old Jul 10, 2006 | 10:04 PM
snosurfa7's Avatar
Thanks so far...yeah, I almost had the same problem on my Jeep, except that I had NO power. That was a fuel pump and faulty wires combined.
Thanks
Old Jul 11, 2006 | 03:35 AM
AgentofDarkness's Avatar
I think the main relay also sends power to the starter solenoid so check out the main relay. I think that the solder joints go bad on those relays sometimes.
Old Jul 11, 2006 | 12:42 PM
land9's Avatar
sounds like a starter problem - check contacts and clean
also, check your engine earth strap
Old Jul 11, 2006 | 01:19 PM
fglaustin's Avatar
think i would try this:
whenever it does that - turn the key off and connect the positive lead voltmeter to the solinoid (at the starter) (carefull that it does not touch anything else) and the neg to a ground, and go in and try to start the car.
see if you get voltage at the solinoid.
you may have a bad switch (switch where the key goes in).
quaterpounder
Apr 22, 2023 05:45 AM
NarcolepticWookie
Mar 14, 2012 08:27 PM
Willie
Dec 20, 2011 03:09 PM
Jmason
May 22, 2010 05:59 AM
Godchild
Aug 30, 2007 08:11 PM
