Steering question
My steering problem still isn't fixed as yet. I spoke to another mechanic and he advised me to check the joint/ knuckle on the steering column to see if it is secure. How can I access this and how do I go about it without damaging anything or triggering the SRS.
[IMG]local://upfiles/18078/DA9542DCA3C843EAB3394D5283E5F1F3.gif[/IMG]
You should be able to see that joint by looking up under the dash. It is a U-joint to allow tilting the wheel, so it is where the column pivots rather than right up at the wheel. There's another U-joint under the hood right where the shaft from the wheel connects to the steering rack.
Looks like you'll have to remove the cover (part #3 in the drawing) to see the interior joint.
norbster86
Feb 11, 2010 04:52 AM
jpnolan
Apr 14, 2009 11:11 AM
prodigyskate5
Jan 21, 2009 01:13 PM
