Stuck oil drain bolt
Old Sep 26, 2007 | 07:42 AM
je55ek's Avatar
Default Stuck oil drain bolt
Last month I bought an '02 LX, and today I tried changing the oil myself for the first time. The only problem is, the drain bolt on the oil pan is stuck. This being my first oil change attempt, I'm not sure how tight I should expect the bolt to be, but this thing is really stuck. It looks like I'm going to have to just suck it up and force it, I appreciate any input!
Old Sep 26, 2007 | 07:55 AM
tknaub's Avatar
Default RE: Stuck oil drain bolt
yup that is the same with my car, you really need to get some leverage and be strong and you will be fine.....
Old Sep 26, 2007 | 08:02 AM
civicexracer's Avatar
make sure ur turning it the right way(counter clockwise). may seem dumb but it happens to me sometimes and i feel so stupid once i figure out i was turning it the wrong way lol. also make sure u use a good socket or box end wrench so u dont strip the bolt.
shsucivic's Avatar
I would take it to a shop and have them remove the plug in case the bolt has been stripped. They can retap the hole to prevent this from happening again.
Old Sep 26, 2007 | 08:03 AM
gwl's Avatar
gwl
Nevermind, I was late to the punch.
Old Sep 26, 2007 | 09:41 AM
Mr Mobsta Man's Avatar
I can't remember if I used a breaker bar or a normal ratchet but I still had toturn it as hard as I can to break it loose.(I weigh 117lbs, so yea I'm not that strong though) Just put some muscle into it and make sure you are turning it the right way.
Old Sep 26, 2007 | 10:28 AM
For those of you who'd like to not run into this situation, and really speed up the oil changes, I highly suggest investing $25 bucks in a "Fumoto Valve." My WRX has one, and its basically the ****
Old Sep 26, 2007 | 02:25 PM
kinosh's Avatar
ORIGINAL: Forty04
I'm considering getting one. Does having (or not having) the nipple make a difference? I have a '92 LX.
Old Sep 26, 2007 | 03:33 PM
Roadkillboy0's Avatar
what is a Fumoto Valve?
Old Sep 26, 2007 | 03:52 PM
CiViC95EX's Avatar
i deffinatly just googled a Fumoto Valve, and I have never heard of it. I am gonna go out and buy one as soon as i get the chance
