sudder/misfire feeling no power
Old Jul 22, 2010 | 01:51 PM
greenbeen4's Avatar
Default sudder/misfire feeling no power
i have a d16y7 turbo and the other day i was driving getting up to 5k and it started popping and backing fire felt like the car was breaking up... the next day it seemed find until driving home it started doing it again except now from 1k to redline car shakes really bad and feels like it has no power at all... i did a compression test and it was 150 across the board, i pulled the spark plugs and they were black i replaced them and they seem to look fine now, i also replaced my o2 sensor took the cap n rotor off all looks fine not corosion or and wear any other suggestions at what it could be ive been trying to figure it out or over a week no and evryone i show it to cant figure it out. btw there is now check engine light and the car idles fine
Old Jul 22, 2010 | 02:01 PM
Pull the codes if you have a CEL.
Have you replaced the spark plug wires and fuel filter?
Have you tested the coil and ICM?
Old Jul 23, 2010 | 01:15 PM
greenbeen4's Avatar
no CEL, i have msd 8.5mm plug wires.. how would i go about checking the coil and icm?
Old Aug 2, 2010 | 06:53 PM
greenbeen4's Avatar
i pulled my valve cover off today and check the valve springs and they were all good no cracks or weak springs, i took out a brand new o2 sensor that i had in the car for a week and it was black as hell my af gauge is reading 20 constantly but when i check the plugs they didnt look to bad either car still idles fine but major lack of power when given gas and a lot of hesistation and missfire feelings please help with any other ideas
Old Aug 2, 2010 | 10:19 PM
Black94's Avatar
check for possible blown head gasket? i blew mine in my d15b7 and it had similar symptoms
jwsimons
Apr 24, 2007 07:58 AM
rajantsr
May 18, 2006 10:38 PM
dj_ipirate
Feb 21, 2006 03:54 PM
MY99SI
Sep 26, 2005 02:22 PM
