Suggestions for SRS light?
Old Dec 3, 2012 | 04:02 PM
bmyz's Avatar
Default Suggestions for SRS light?
98 civic CX with driver airbag only.(in steering wheel)
SRS light is on
what should i look for?
Old Dec 3, 2012 | 04:45 PM
I think that model is old enough that you can put a test jumper wire in the ECU test plug, turn the key on but don't start, and the SRS light will blink out a code.
A common problem is breaking the "clock spring" that electrically connects the air bag on the wheel to the rest of the car. Does the horn work? It goes through the same part.
Old Dec 3, 2012 | 05:52 PM
bmyz's Avatar
The horn works well off both buttons.
It's dark out now so i haven't checked for a code. New to a honda so not familiar with jumpering the ECU. What should I look for.
OBD2 doesn't show anything
Thanks
fivebells
Aug 9, 2014 06:10 PM
houstonwide
Nov 17, 2005 09:57 PM
vmf
Aug 1, 2005 11:43 AM
Josh1122
May 4, 2005 05:50 PM
ettrump
Feb 23, 2005 05:28 PM
