temp sensor
Old Mar 12, 2008 | 02:59 PM
woody dog's Avatar
Default temp sensor
Car is 93 civic car was given to me. I was told the temp gage has not worked since head gasket was replaced. Where is the temp sensor? Any suggestions. Thanks in advanced.
Old Mar 12, 2008 | 03:06 PM
Default RE: temp sensor
Check whether fuse 15 is blown. If not, I think the coolant temperature sending unit is near the distributor and next to the coolant temperature sensor.
Old Mar 12, 2008 | 04:23 PM
woody dog's Avatar
Checked fuses and connections still no temp. I dont think fan comes on either. ^ Thanks for reply still trouble shooting.
Old Mar 12, 2008 | 06:02 PM
The coolant temperature switch that controls the radiator fan should be on the thermostat housing.
Old Mar 13, 2008 | 07:27 AM
The sender for the gauge is screwed into the end of the head, underneath the distributor. It is the one toward the back of the car, with one wire. Probably they just forgot to plug the wire back in. If you unplug the wire and ground it, the gauge should go all the way to hot when you turn the key on. This will prove the wiring and gauge are OK, then the only thing left is the sender itself.
Old Mar 13, 2008 | 01:56 PM
woody dog's Avatar
Just got back from buying a Haynes manual. I will figure it out and post back. I like the car the tacoma has not came out of the garage for a week +saving money on gas [sm=w00t.gif]
Old Mar 14, 2008 | 04:05 PM
woody dog's Avatar
ORIGINAL: mk378
That was it I ground it gauge worked replaced sender and all good [sm=icon_rock.gif]
fglaustin
Mar 27, 2008 08:29 PM
windcalmer
Sep 6, 2006 10:22 PM
trebor_2005
May 19, 2006 01:40 AM
cdansley
Apr 22, 2006 03:59 PM
hcambron
Dec 1, 2005 10:42 PM
