throttle position sensor voltage question
Old Apr 23, 2007 | 03:46 PM
darkneck's Avatar
Default throttle position sensor voltage question
I read in the manual that the TPS should read .49V when throttle is closed. I have a scangauge and the gauge gives me a reading of 9 when closed and 87 when wide open. Can someone with the scangauge tell me if this is normal operating conditions.
Thx
Old Apr 24, 2007 | 06:44 AM
Default RE: throttle position sensor voltage question
Details on the car, and what is a scangauge?
Do you have a multimeter? Did you adjust the TPS at all recently? If soit may just need to be re-calibrated. If it did take a dump you'll need to change it, which is a bit irritating, but can be done.
Also, let me konw if you need a new one, I've got a couple in the garage
EightyNineDX
Dec 5, 2012 04:06 AM
aree
May 8, 2007 07:00 AM
nightrider46
13
Sep 29, 2006 10:00 AM
Belmont
Apr 18, 2006 02:37 PM
pbrooks259
Oct 3, 2005 11:06 AM
