thumping noise in front end replaced Bearings HELP!!!
I am having issues with my 95 Honda Civic. I have been having whup-whup-whup sounds in the front end. I think it is coming from the driver's side. it is loudest between 20-50, not when braking. does not change when steering to right or left. It also causes a slight vibration. This is what I have done, replaced both front wheel bearings, still noisy, Took of rear left bearing, looked bad so I replaced it too, still noisy. when I remove wheel and run the car in gear while wheel is off and rotor is held down with a couple lugs the car makes a little noise and the caliper vibrates. could the rotor cause this even if it happens when I am not braking? what else could it be? PLease Help I am ready to get rid of my beloved civic, this has been a thorn in my side for months, the shops keep telling me I need new bearings but I already had them changed!
Do you have the right bearings? I have a non-ABS civic and for some reason my front knuckles are from an ABS civic. The bearings for ABS and non-ABS are totally different.
Unless the rotor is EXTREMELY warped I don't think that that's it.
Do you have directional tires?
Did you get new wheels? OR, do you have aftermarket wheels? Our knuckles are hub-centric and a piece behind aftermarket wheels sometimes falls off (that allows the wheels to be hub-centric) while changing tires.
Get you tire inspected/balanced.
Thanks danomatic, Funny you should bring that up. My civic does not have abs, but the bearings that were made for the non abs models were definately not right, they had different dimensions so I tried the ones made for abs and they were identical to the ones I removed. Not sure about the directional tires thing, but I will check. The first thing I did was replaced two tires that were cupped on the fronts with two newer used tires, that I had mounted and balanced, and that didnt change anything.
dito might try swaping the tires to the rear and see if theres a difference or not.
since you said it has a vibration im gonna agree either the rim is bent outta shape or maybe the alignment.
thakid
Dec 14, 2011 01:48 PM
98civicjdm
Oct 2, 2010 07:21 PM
dsilentninja
Apr 2, 2009 05:50 AM
klipschfan4life
Aug 6, 2007 04:32 PM
Narcoleptic724
Dec 3, 2004 08:58 AM
