Ticking/clicking on start
since about mid summer my engine has made a ticking/clicking sound when I started it. At first it did not occur all the time, and would go away fairly quickly. Now that is has been constantly sub zero temperatures it happens every time I start it. It is very loud and takes about a minute or 2 to go away.
Now I figure its my valve clearances that need to be adjusted. But If anyone has an other suggestions before I take off the rocker cover and go messing around with that I would appreciate it.
(and yes the rate at which it ticks and clicks increases with the RPM)
It could be that you need to adjust the valve clearance, though I would first check whether the engine oil is low. Also be sure to use 5W-30 oil as opposed to more viscous oils that take longer to pump up to the head.
dwills898
May 9, 2014 03:14 PM
Sandipb08
Nov 27, 2011 12:30 PM
briceman124
Sep 7, 2011 07:26 AM
Whitehead
Mar 2, 2010 07:22 AM
97Coupe
Oct 22, 2007 02:35 PM
