timing belt
Old Apr 7, 2005 | 07:40 AM
firzout's Avatar
Default timing belt
i'm redoing my timing belt. someone said to place a pin on the cam. what kind of pin? and where on the cam? i'm just lining up the two dashes on the pulley to the egde of the head with the "up" word directly up. will this by enough?
Old Apr 9, 2005 | 06:59 PM
sacicons's Avatar
Default RE: timing belt
there are two holes in the cam covers, or where the cams ride on a sohc, and when its exactly at tdc, you can slip an allen wrench or other appropriately sized metal rod into the hole, it will go into a hole in the cam and lock them in place. then you set the crank pulley at tdc, and slip on the belt. its simple. ill try to get pics, but my lifes busy as hell right now, so i dont know when ill get a chance.
Old Apr 9, 2005 | 07:18 PM
Kappa22's Avatar
And when you're putting the belt back on, make sure that you put it on with the slack on the tensioner side (keep the side that goes between the cam gear and crank pulley taught).
smackpower
Jan 13, 2024 01:42 AM
Kyle700
Sep 18, 2014 07:44 PM
marcpasek
Oct 16, 2010 09:49 PM
pippo
Jan 26, 2010 02:40 PM
thakid
Jan 30, 2006 08:29 PM
