Timing Belt
Old Feb 2, 2010 | 08:06 AM
Jason D's Avatar
Default Timing Belt
I need a little help on changing my timing belt on my 95 del sol v tec. i got the cover off of the cam pulley, then what? is it like another belt and has a belt tensioner? what do i do? thanks
Old Feb 2, 2010 | 08:51 AM
This is no job for a beginner who has done little or no research on the topic.
You need to bust loose the dreaded crankshaft pulley bolt. You'll need either a very strong impact wrench or the special Hex Tool, two breaker bars, and a 3 ft length of metal pipe for extra leverage.
Old Feb 2, 2010 | 09:27 AM
Jason D's Avatar
I have done this before but not on a honda. but i do need to take the crankshaft pulley completely off? and make sure i put it back on the same way or ill throw it out of time? the belt was just changed last month but something got in side and burned a groove in the belt and i know that he did it by hand so my impact should work no problem. if i do manage to take it out of time with cylender is 1 and which is air valve so that i know i can put it back in time
Old Feb 2, 2010 | 09:46 AM
Download the 92-95 Civic service manual at the link in my signature. In the Engine, Valve train section, replacing the timing belt is covered.
Old Feb 2, 2010 | 10:00 AM
Jason D's Avatar
Thanks alot
smackpower
Jan 13, 2024 01:42 AM
Kyle700
Sep 18, 2014 07:44 PM
marcpasek
Oct 16, 2010 09:49 PM
pippo
Jan 26, 2010 02:40 PM
thakid
Jan 30, 2006 08:29 PM
